what the hell should I look for??
Old May 24, 2009 | 10:03 PM
VINCE's Avatar
Shorty Director
Originally Posted by ayousef
I have to agree thats likely to be a problem, ill start looking, any suggestions how to locate those leaks by any chance?
You can either check all connections or make yourself a boost leak tester. I went to a local hardware store and purchased pvc caps to cap off my air bridge and my turbo inlets. I used a pressure gauge and shop air to push air from the air bridge towards the turbos. Dont forget you will have to drill a hole in the cap and purchase the necessary connections to work with your gauge and shop air. I set the pressure gauge to 10 psi to start and worked my way up to 20lbs. If you have a leak you will quickly discover. Its not a perfect checker, but it helped me find my boost leaks.
