Will i run out of Injector?
Old Nov 5, 2003 | 04:16 PM
Blk00WS6's Avatar
Default Will i run out of Injector?
If i go with 72cc LS6 Style Patriots{Which should give me a 9:1 compression ratio right?} with LPE GT2-3, Procharger D1SC, 42# Injectors, Holley FP. Will i run out of Fuel?
Old Nov 5, 2003 | 05:03 PM
MYTURBOT/A's Avatar
depends on how much boost your running? Is that holley pump an intank or inline pump and whats the LPH rating on it? yes that will be 9.1:1 comp if you have stock flat top pistons.
Old Nov 5, 2003 | 05:31 PM
Blk00WS6's Avatar
I'm going to be running 8.5Psi of boost. The Holley is an Intank pump and it's LPH rating is 255
Old Nov 5, 2003 | 07:43 PM
ChrisB's Avatar
Might as well go ahead and get the siemens 57lb/hr high impedance injectors that racetronix is offering - price shouldn't be much different, but you will have more head room.
Old Nov 5, 2003 | 07:58 PM
MYTURBOT/A's Avatar
You should also look at a twin intank set up because you`ll be pushing the single pump to it`s max. I think with the twin intank pumps and a boost ref. FPR you will be fine. but the 57lb/hr injectors are in your future if you up the boost . I heard the 50lb injectors are easy to tune and they should work good for you.
Old Nov 5, 2003 | 08:17 PM
Slowhawk's Avatar
LS1Tech Sponsor
I've had cars push 460hp with 8psi,42lb FMS injectors and stock fuel pump with Kennebell boost a pumps set at 15% with no problems.They have drag raced and been street driven for over a year with no problems.
Old Nov 5, 2003 | 10:18 PM
Blk00WS6's Avatar
With the Setup i'm going to be running.... I'm hoping for 550Rwhp+ if i go with the heads. Maybe i should upgrade to bigger injectors
