Nitrous and boost
Here is mine..
i like that setup but have you thought of running a stand alone fuel system to the dp with nos and meth as your fuel... that would be a killer setup and prob the most effective in both aspects... alot of nos guys run meth just make sure the solinoids are made for it..
As I'm sure that the guys spraying in the intake are already aware, IAT sensor is not seeing the benefits of the reduced charge temp and wont be able to apply any modifiers that may be in the tune. Also, the PCM cannot make any fueling corrections if the car is using a MAF.
AFR prior were 11.4-11.6:1 but i never checked after....it sounded good. It ran for 2 years and is still great. ran 10.55 @ 128 w/o and with the 50 shot ran 10.33 @ 131. gained about a tenth in the 60ft. Most noticable off the line. I had some lag and it made up a bit. I dont know if that gives you an idea what a 50 shot does. My converter was really loose. .
Put it into the engine as close as possible.
Spraying it on the IC is using it to reduce the IAT temps.
