30psi with a trubo come in
Old Jun 16, 2009 | 11:50 AM
cjg454ss's Avatar
Default 30psi with a trubo come in
anyone running 30psi? if even possible, i havent pushed water at 21psi so far with my oringed block very low compression 8:1 on pump gass. was thinking about 25 with some 110, i also just picked up a alky kit to help. any infor would be appreciated.
Old Jun 16, 2009 | 12:23 PM
Fireball's Avatar
I hit 30.4 psi
Mike Brown said he's been 34psi
Old Jun 16, 2009 | 12:36 PM
cjg454ss's Avatar
Originally Posted by Fireball
I hit 30.4 psi
if the compression is low and the intake temps are reasonable, would 30psi be anything to worry about? with octane to support it? i see most people stop around 22-25psi on here.
Old Jun 16, 2009 | 12:37 PM
Fireball's Avatar
I wouldn't try anything less than C16 IMHO
Old Jun 16, 2009 | 12:38 PM
Phil99vette's Avatar
7 Second Club
Well it all depends. The MOST important question is how much timing are you running?
30psi and 10 degrees is way different than 30psi and 25 degrees.
Old Jun 16, 2009 | 01:55 PM
cjg454ss's Avatar
im thinking about trying 25-27psi and 15* timing to start, 110 sunoco and 28g/hr twin nozzle meth injection. or would it be better to run 23-25 psi and 20* timing.?
Old Jun 16, 2009 | 02:10 PM
7 Second Club
The more timing you run the more cylinder pressure your going to make which will eventually lead to pushing coolant. I run as much timing as possible at every boost level.
