What to look for in a cylinder head for boost
Old Nov 11, 2003 | 12:19 PM
Ryan23silverado's Avatar
Default What to look for in a cylinder head for boost
I have been gathering information, and I will be doing cylinder heads soon. I have a general question for you FI guys though:
What do you look for in a Forced Induction cylinder head? Is just the best flowing numbers at the lift your cam will see what to look for? Does it matter if the ports are hogged out for highest flow numbers because you are boosted? I know many F/Ybody guys go with 6.0L heads to lower compression ratio. I will be running the new heads on a 5.3L, so even an LS6 head would be a drop in compression ratio for me.
Just an example, but I have been looking at Patriot Performance's stage2 LS6 heads. Also, I have been looking at TEA heads, but trying to find more info on them such as price and port volumes. TEA seems to have the exhuast port down..they flow really well on the exhaust side. What are you guys running and what rwhp gains have you seen with the addition of heads?
Old Nov 11, 2003 | 01:03 PM
Nasty N8's Avatar
They are completely differant from a standard "Stage2". With boost heads don`t mean alot let the boost do the work. There are some tricks to making them perform well though. Low compression of corse and you want to see a good flow from the exhaust side and very polished. You want good valves and bronze guilds to handle heat. We have done quite a few boost heads that have done very well. Looking for further info give me a call.
Nate
Old Nov 11, 2003 | 01:05 PM
BIGBOS's Avatar
I got some Stage 2 TEA 73cc 5.7L heads that have worked well so far, haven't put them to the real test yet, but they are very good quality....
