EPP Front Mount F1A Air Inlet
Old Jun 23, 2009 | 04:59 PM
laughatrice's Avatar
Default EPP Front Mount F1A Air Inlet
Anyone have any pictures of their air inlet setup with a front mount intercooler the EPP if possible. I'm having trouble getting the filter inside the bumper behind the fog light due to the race valve in the way.
edit: its on a camaro by the way
Old Jun 23, 2009 | 10:17 PM
SELLSZ06's Avatar
im running my own intercooler otherwise i send you mine, but sounds like maybe you welded(if you welded it yourself) it in the wrong spot? My bypass is on the other side between the blower and cooler.
Old Jun 25, 2009 | 10:52 AM
I didn't weld it myself I though about that but I can't find enough pictures to verify it's in the right place.
Old Jun 25, 2009 | 11:37 PM
BLASTER's Avatar
you have any pictures? what spot are you hitting?
i am trying to figure out this side to. i don't have the EPP kit (building my own) but I know they place it right after the FMIC outlet right before it goes up through though the frame hole (where the air pump used to be) near the fuse boxes.
i am about to put my BOV on the bend right after the fuse boxes before the my MAF. can you relocate yours?
Old Jun 26, 2009 | 06:31 AM
AFASTYZFR1's Avatar
Race Bypass location he is talking about:
Inlet Example:
Let me know what you come up with.....my bypass is in same location and I have not had time to come up with something yet. But I was informed there is no way to get the truck inlet to work
Old Jun 26, 2009 | 12:42 PM
Yea same problem as me. I know I have seen the race valve up near the throttle body. I didn't have the fabrication tools to engineer something so I took it to my shop and told them to deal with it. I'll post pics of what they come up with.
