Procharged Iron Block??
Old Nov 14, 2003 | 02:01 AM
Toonz's Avatar
Vince... no way brother... I was lucky to make the 32 hour round trip to Bella Rosa with no tickets! Don't want to push my luck with another road trip for a while. Guess I'll be gunning for Kyle's car in March.
Old Nov 14, 2003 | 09:15 AM
NA$TY-TA's Avatar
You better bring a bigger gun the then that .22 you have now.... ha ha
What all are you guys running vuel system wise.
What is the max HP w/ 42# injecters and good fuel pressure?? I have a Walbro 340 intank now and im either going to add another 340 intank or go with an inline. What can the fuel lines support??
Thanks
Kyle
Old Nov 14, 2003 | 09:47 AM
RyanJ's Avatar
SSU Moderator
Cant the stock returnless lines work up to 500rw? I can't remember. Harlan made 500rw on a mustang dyno using stock lines (w/ a return) and a single intank (w/ some mods). I'd run the same rear setup as 'smokinhawk'(?) - dual 340's, -8 feed, regulator, and the stock feed as a return. Oh, Harlan had 42's too. With enough pressure you may get 42's to 600.
Something to think about, though. www.acceleronics.com makes a injector converter. The guy runs a ys-trim LT1 w/ at least 72lb injectors on the street w/ no issues. That would help.
