Procharger Question
Old Jun 26, 2009 | 08:53 AM
SS LeadFoot's Avatar
Default Procharger Question
There are 2 brackets on the back of the polished airbox where do you bolt those? I don't have mine bolted just wondering if anyone else does. It doesnt look like there is a place for them. I ask because my airbox is rubbing the hood. Any pics would be great. Thanks for any help
Old Jun 26, 2009 | 04:33 PM
WS6Drop's Avatar
Mine are bolted. Drilled a couple of holes on the assembly that goes over the radiator and fan assembly.
Old Jun 26, 2009 | 08:28 PM
underpressureWs6's Avatar
i drilled two holes in the radiator shroud to use the 2 brackets but bolted down the plenum would pop the shroud off the radiator and the radiator would shake back and forth so i just dont use them anymore, instead i shot a bolt through the front tab on the plenum, which works much better.
