throwing belts
Old Jun 28, 2009 | 07:25 AM
jomomma's Avatar
Default throwing belts
im throwing the belt like crazy. i had to shim a corvette procharger bracket out to match up with my fbody pulleys. it was staying put under normal driving. then i changed out the tensioner, and now its spitting the belt at will! this is what the setup looks like.
my question is do i use the crank pulley for reference to match the other pulleys to?
Old Jun 28, 2009 | 08:12 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Yes, match the other pulleys to the crank pulley. The crank pulley is not adjustable
Old Jun 29, 2009 | 04:52 AM
EPP's Avatar
EPP
Either you have a serious belt alignment problem, or the bracket, etc is flexing under load. Bob
