help..tt intercooler on single t70
Old Jun 29, 2009 | 04:23 PM
chevellepowered's Avatar
Default help..tt intercooler on single t70
i have a twin turbo intercooler from my past build. from ebay.. two inlets on the bottom sides.. go threw the top 3inch, couldnt i still use this for my single turbo build.??.. maybe block off one side and just route it to one side..
this exact one http://cgi.ebay.com/ebaymotors/CXRac...1%7C240%3A1318
where it comes in the bottom inlet its block from the other inlet.. , should i run pipe to both inlets..??. help!!
Old Jun 29, 2009 | 04:26 PM
nastychevelle's Avatar
cut off one pipe and have a good welder tig an aluminum plate their to block it...
Old Jun 29, 2009 | 04:33 PM
yea i thought about that.. then i would only be using half the intercooler.. since the other inlet is seperated from the other inlet.. wierd design.. thanks..
Old Jun 29, 2009 | 04:36 PM
Darren P's Avatar
Put a Y in the charge pipe, or have someone put a single tank on the bottom. or trade it for the correct one
