Boost leak symptoms and speed density.
I want to be able to go higher on boost although probably not with these current turbos and do eventually when everything is running right hit it with small shot of spray.
So not sure if should go to tr7ix or tr8ix. With spray think tr8ix without tr7ix should be ok I think. Aps also recommended the irdiums in their manual. I have used iridiums in my talons a lot. No complaints. Not platinum plugs though. I realize most like the cheap copper ngk but this car is not that easy to change plugs on . As said think the back couple are not going to be fun at all and put them in when did the motor and it was out of the car.
I am still going to wait a day or two for few people to look at my logs and tune. As if it is something in there then would leave the plugs which are almost brand new and change them out over winter when change out to the upgraded turbos from likely LG.
Please feel free to look over my tune and see if there is anything that jumps out.
This thing still seems to do this any rpm and any gear when you go wot boost or not.
You need to have the "ses enable" checked for 101.102 and 103
Have you done any logging with this setup to build the VE table?
Anyway, as most others have said it sounds to me like your misfire problem is due to plugs/wires.
I've seen plenty of melted plug wires on APS cars and changing the plugs is rather easy IMO. Start by checking the plugs/wires then properly tune the VE table.
To start with anything else will be a waste of time.
Ok just put in the table from stock ve or mabye it was from a 2001
since my 99 original got deleted accidentally. I did it from instructions on hptuners and raised it 10% on top line not 25% like they did .
Why do i want the pe and be to be same? I thought the purpose of having two tables was so you could be leaner when not in boost for best off boost power? I thought be table overrides pe as soon as you go into boost?
i thought you get ses light if you check this .i am pretty sure seen lots of speed density tunes on hptuners with this unchecked? Are you 100% sure on this. If true my car is not running on speed density that could be huge issue?
Have you done any logging with this setup to build the ve table?
No logging yet to build ve table.
I've seen plenty of melted plug wires on aps cars and changing the plugs is rather easy imo. Start by checking the plugs/wires then properly tune the ve table.
Ok i did burn an accel wire the granatelli have much better heat protection although are pricey. So since going to the lg upgrades likely mabye in next few months and want to run small shot of spray do you think the tr8ix would be ok choice and what for gap..
.028 or a bit less? Don't want to keep constantly swapping in plugs.i have read you can run colder iridiums and not foul in normal street driving.
Also though on second log a bit diffferent why does my car go to open loop on highway not in boost at such low throttle position? Is it supposed to go to open loop when barely into the throttle?
