Phamspeed .. Fact and Fiction ??
Sorry I don't have any old pics of this set up, and I'm surprised that those pics show up, maybe search my screen name will turn up more pics or posts....as I posted up quite a few.
In this video you'll see the crossover and DP as I go over the speed bump...be forewarned you'll have to go this speed over EVERY bump and dip...
http://www.fquick.com/videos/Turbo_s..._and_test/1703
If you have a fabricator buddy, or if you can do it on your own...cut out the round tubing that goes under the K member and replace it with ovalized tubing from dr.gas or other exhaust tubing suppliers. Both the crossover and the DP will benefit greatly from this and you will too
Hope this helps,
J
Hope this helps,
J
Damn man you car sounds crazy, I know you posted on their you werent running a full exhaust but i always thought turbo cars were supposed to be pretty quiet.
Good luck with that kit. Does the downpipe run under the stock k member or are you running an aftermarket peice?
that is a damn good price
Don't think about doing it DO IT!!!! You will gain a ton of clearance.
melscrilla, yeah it does have a bit of a lope to it
Even through the cat back its pretty damn loud
Im a welder/fabricator so buying a used kit & doing my own work makes it cheaper than buying a high end kit straight out. some of the welds on the original parts are "ok" and like what was said, I wouldve prefered a full mandrel bent downpipe over the "japanese style" sections welded together, but all in all I got it for a good price and Im happy with it!
My TA isnt lowered at all (yet) and so far so good! but just take it easy over speed bumps and approach steep driveways at an angle, lol.
Awesome replys guys, thanks a lot for the help I would love to see some pics, something that might help me in the mean time figure out how to modify and how to ease the installation, although I think I am going to install this kit when I do 317 heads and a z06 cam swap.
