can someone help me out with my setup?
Old Jul 15, 2009 | 12:47 PM
camaroman285's Avatar
Default can someone help me out with my setup?
i have a 35th le camaro and its got a innovative front mount single turbo. when i shift or let of at high rpm i get sum oil out my exhaust running 5w 30 oil and 6psi on a stock motor only 9k on the car maybe 3k w turbo on.
Old Jul 15, 2009 | 12:50 PM
IT_SS's Avatar
....could the oil be coming from the turbo hot side?
Old Jul 15, 2009 | 02:22 PM
um maybe i think its draining back from my oil return line going from the turbo to the oil pan, because the turbo sits almost as low as the oil pan so the line goes straight across to the oil pan, it doesnt angle down at all so i think when i let off it might be getting a little bit of a vacum and sucking a little back to te turbo if that makes sense
Old Jul 16, 2009 | 07:54 AM
MY99TAWS6's Avatar
Makes sense you likey need to add a scavenger pump. They are fairly cheap and pretty simple to install.
