godzilla turbo
Old Jul 27, 2009 | 10:06 PM
jrocstar's Avatar
Default godzilla turbo
okay i have been trying to figure out a good size turbo for my 6.0 turbo build. I was offered a godzilla turbo. its a t76 turbo journal bearing t-4 flange. the compressor is a 76.8mm inducer and a 102.35 exducer with a .80 ar. the turbine is a 72.28 x 64.2 with a .81 ar with a 3'' vband. does this seem to small for hp goals of atleast 700 wheel. I am planning 20 psi. if it is not right i am open to suggestions.
Old Jul 28, 2009 | 03:16 PM
jrocstar's Avatar
anyone have any suggestions?
Old Jul 28, 2009 | 04:05 PM
RAACCR's Avatar
1. Its an ebay piece of crap.
2. The compressor would be barely adequate for a mild 6L motor.
3. The turbine wheel is way too small; it will choke a 6L motor and cause very high backpressure.
At a bare minimum, you'd want a 76 or 78mm with a .96 a/r S trim turbine, or better yet, a T88 (if you need to stay with a T4 footprint) or even a T6 (you can get some great deals on Borg Warner T6's that are hardly any more $$$ that that ebay "Godzilla").
Contact one of the vendors on the right and it will save you a ton of money and trouble in the long run ------------->
Old Jul 28, 2009 | 09:23 PM
ScorpionT's Avatar
You will definitely need something with a bigger turbine housing. A decent 76mm can definitely make 700whp.
Also, the BW stuff is definitely worth more than the Ebay stuff. The only reason the cost is lower is because its VERY high production and they dont see a reason to charge a ton of money.
Old Jul 28, 2009 | 11:08 PM
Reject's Avatar
modularturbo has GREAT deals, he'll get you setup. that turbo you mentioned wont do you any good. also 20psi on that thing? gonna heat that air up quiet a bit there
Old Jul 29, 2009 | 11:12 AM
DrTurbo's Avatar
LS1TECH Sponsor
Just give us a shout. We will get you setup with the right unit.
Old Jul 29, 2009 | 09:57 PM
jrocstar's Avatar
i have a custom made intercooler for 1000hp. it was used on my old setup with a v6 and a 35r but i did not think 380whp was justice for that intercooler so i am upgrading the setup mildly for now t88 later i am looking a street fun 700whp. so 76mm was my first thought and that should be enough
