Ready to install my lg replacement aps turbos!
Thanks, Barnat
I don't think you need any kind of tank with the scavenger pump. Just run the lines from turbo to y block and then into pump and out to one of the pan fittings. Just block the other fitting.
Good news on your new turbos Barnat. I forget you have to drop engine mount bolts too to drop k were they hard to do with the turbos on there still? Should have took some pics for us of the swap out.Mabye you still can...
Ill probably see the turbos this friday!
Also unfortunate that anyone has to take out their turbos but life sucks and then you die.
At least Barnat,Tomz28 and few other lucky guys should have insane new LG snails in there and hopefully can say goodbye to turbo problems.
Very interesting in seeing some new dyno numbers from various combos with the LG snails. Should be putting out big numbers at not that high boost level.
To tell the truth my car can actually scare me and it sure can scare just about anyone that have given a ride to at only 8psi and the standard turbos on the built 408. Can only imagine what those new snails will be like at 12, 15..or even higher psi. Warp speed or what! I would suggest anyone getting those seriously look into some upgraded brakes.
or maybe a parachute! LOL
These turbo cars are so damn visious. And VISCIOUS IS GOOD!
