TC78 vs T76?
I honestly don't know. It should make more than the previous setup at the same boost levels. I think that you will make the number in tq, but anything I predict about how it would act up top would be a guess to be honest. My gut tells me that the exhaust housing and those cubes may not be a match made in heaven. Having the most free flowing exhaust would be a plus and would help it out up there.
I'm interested to hear how it will turn out.
Engine: 383 LT4
Heads: LT4 Ported
Intake: LT4
T/B: 58mm
Compression:9:5:1
Cam: 23X-23X/ 588-588 on a 114 LSA.
Tranny: M63
T-76 with a T4 flange and a .96 AR
Now take that HP76 turbo and remove the S series compressor cover and the backing plate. Machine a custom backing plate and add the smaller 60 series compressor cover....now it's a "TC76" turbo. Still has the HP76 guts in it.
TC76 is just an HP76 with a smaller 60 series compressor cover for packaging.
Now to add confusion...you can take a HP76 turbo...take off the standard S series compressor cover and add the larger race GTM Compressor cover for even more power....but it's a biggg cover and needs plenty of clearance.
GTM Race Cover 76 turbo > HP76 turbo > TC76 turbo
We made 655 @14 psi on the same truck on the pump gas tune with the 22" wheels.
We never dyno'd it with the TC78, 1.15 a/r but it traps the same mph now on 15psi as it did before at 19.
LOL...new meaning to Fast DUB's
I currently have the small cover TC76, .96AR, P trim wheel. Im wanting to try the T78, 1.15AR, S, or F1 wheel like you said. Could that swap be worth a couple tenths on a low sec truck?
