Going Turbo - need help
Old Aug 15, 2009 | 10:55 PM
sspower23's Avatar
Default Going Turbo - need help
So I have a 2001 camaro SS, LS1 346ci V8 6speed, planning to go Turbo. Which turbo setup should I go with? I was thinking STS because theyre kits are "rearmounted" and SMOG legal/emissions free. I want a twin turbo setup only because I think it works better and faster than a single turbo. Who should I go with?
Also because I will be putting out so much torque, which Twin-disc CLUTCH kit and which REAR-END should I go with?
Thanks
Old Aug 15, 2009 | 11:50 PM
TurboAv's Avatar
Search is your friend. Or just spend a few hours going page by page reading the FI section. That being said STS is craptastic. I had one on my Avalanche and it shat oil all over my engine bay when the abortion of a PCV system failed. If you want a rearmount find a local shop and have them do one. They aren't rocket science and it would be WAY cheaper than a cheesy STS kit.
Old Aug 16, 2009 | 01:31 AM
black98ws6ta's Avatar
Cliff note's:
Do a front mounted system.
When sized properly twin's and singles will work very similar.
A twin disk would be a good investment, I personally have had good luck with Spec from 600rwhp to 1000 rwhp.
I would do a Moser 9'' for the rear.
