Electric Fans a Must?
Old Aug 17, 2009 | 11:37 AM
Chronicle's Avatar
Default Electric Fans a Must?
I am pulling parts together for a custom made front mount turbo setup, and would it be a good enough investment to buy new electric fans for engine bay room?
Old Aug 17, 2009 | 12:29 PM
pwrtrip75's Avatar
Stock ones work good, probably hard to find an aftermarket one to beat it.
Old Aug 17, 2009 | 12:36 PM
AFASTYZFR1's Avatar
If you can keep the stock fans, I wouldn't change them.
Old Aug 17, 2009 | 02:48 PM
SUPERBOOST's Avatar
Don't know what kind of turbo setup you are doing or your plans for your radiator but if you have the room use the factory fans,they are hard to beat.Most likley though you will have to go to aftermarket fans to get the room you need.Keep it a puller setup if at all possible,they are much more efficiant than pushers.There is lots of good info on here about radiator and fan setups.Someone can probably hook you up with a link but one good thread is"those that stood the radiator up and vertical" or somthing close to that.
Old Aug 17, 2009 | 03:15 PM
pwrtrip75's Avatar
Just mount the turbo up higher, then you can use stock fans (depending on how big the turbo is).
A different radiator was used set up straight and underneath the radiator support. You could use the stock radiator if you cut it out. But my setup has the stock fans.
Old Aug 18, 2009 | 11:27 AM
Chronicle's Avatar
I'm using a TC72, so not too big or small. I like the idea of moving my radiator if I can. Any suggestions on how I could pull that off?
Old Aug 18, 2009 | 12:00 PM
BadgeZ28's Avatar
consider replacing your LS1 radiator with a LT1 unit. They are a direct fit in F-bodies and have about 30% more coolant capacity.
Old Aug 20, 2009 | 10:43 AM
Chronicle's Avatar
Are they any smaller? Would replacing it give me more engine bay room for my setup?
 Michael S. Palmer
Old Aug 20, 2009 | 10:53 AM
BadgeZ28's Avatar
Nope. Same overall size and one row thicker core.
Old Aug 20, 2009 | 11:34 AM
oehq's Avatar
We have the OEM GM radiator 52466004 in stock for $254.74
and also an aftermarket unit Spectra Premium in stock CU1486 for $142.29.
Sprectra is a great product so I would not hesitate to go with that unit if price is an issue.
these are both Z28 with LT1 engine for 1995 Z28
Hope this helps
Oehq
