making the switch from procharger to turbo !
He's working on the truck right now actually...
The engine is a forged 383 with ARP goodness all around and a set of ported factory heads. I believe it's about 9.5:1 SCR. The truck never mad a solid pass or dyno pull unfortunately. In the beginning there were wiring problems (and a 98 PCM ugh) but once they were solved, belt problems showed up. It used a corvette arrangement for the SC and even after the 8-rib pulleys and lots of work, we could never get the belt to hold well past 10psi. Here is video of it from a few years back (it was open rear then too!) http://www.tunedbyfrost.com/vid/jarrell.wmv right-click and save-as.
i then put this back in it......
its a strange pro case with 1350 yoke, detroit locker, 3:70 gears, and 35 spline axles. should`nt have any more problems out of the rear!
i got the truck running, but it needs tuning badly. heres a couple of pics.
ive got some bugs to work out, but i hope to get tuned maybe next week
If you get to go to the track friday send me a text. Im hoping to be up there if we can finish the C4 trans install on a 03 Terminator this week. Trying to get it ready for the Terminator Shootout at MIR.
So I decided to take it to the track anyway last night just to see what ballpark I am in. I ran a 11.92 at 116mph at 8psi of boost. I was fighting over boost all the way down the track and kept the TPS at roughly 70%. I am going to try to correct my over boost and fuel pressure drop situations in the next couple of weeks.
i cant wait to take it out again. hopefully nobody will call the cops on me this time!
