Pics of the other eBay kit
I forgot the size, but I went with the size Forced Inductions recommended, which flowed quite a bit of oil... It would immediately spill into the exhaust housing and create a smoke show...
I didn't want to add more restrictor, so I ran a scavenger pump to pull the oil...
This was the case with both a T-70 and the T-76GTQ I run now...
Turbo sits very close to the level of the oil pan with this kit, IMO.
As long as your turbo is getting the right amount, it's all good.
The adapter to my oil feed had a restrictor made into it, so I really don't know the size of the feed. I can say this, it doesn't smoke. My drain is just above the oil fill line so there is about a 2" drop
Also those who have installed this setup, what issues if any came up in the build?
DM
I just want to see how it looks on, do you have to do the vert. radiator mod? Fan changes? I am going to start my kit this weekend, there is one modeled exactly like it on the bay .. at least there was a few weeks ago .. ill post pics tuesday of progress/failures
