Update to my BS3/Backfire issues...
Old Aug 29, 2009 | 08:08 PM
Jimmy P's Avatar
So is it safe to say that the backfiring was caused by the bad IAC sensor, and the BS3 not being able to power up/communicate with the laptop was caused by the secondary chip being fried?
My BS3 car had a bunch of backfiring issues last year that we couldn't figure out, until we took it apart to change a few things around and found the IAC sensor was bad..
Old Aug 29, 2009 | 08:30 PM
BlwnTA's Avatar
7 Second Club
Thanks for the info Brian, you gonna get that heap back together and get that 7 this year?
Old Aug 29, 2009 | 09:31 PM
Fireball's Avatar
maybe...maybe not...there was also a huge variance in the injectors causing some cylinders to run very rich.
Old Aug 29, 2009 | 09:32 PM
Fireball's Avatar
maybe
Old Aug 29, 2009 | 10:40 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Congrats on diagnosing some problems, and good luck next time out!
LS1Tech Co-Founder
Old Aug 29, 2009 | 10:57 PM
onfire's Avatar
Coal Mining Director
Echo?
Old Aug 29, 2009 | 11:10 PM
LASTLS1's Avatar
6 Second Club Moderator
Glad to hear you found the problem.
Old Aug 30, 2009 | 08:23 AM
Fireball's Avatar
son of a....
measured coil resistance in the IAC. I found some info on LTI IACs, but I think the coil info is still relevant. Essentially, coils should be between 40 and 80 ohms and no continutity between coils.
what mine measured at the BS3 harness:
Coil A (A-high to A-low): 48 ohms (in spec)
Coil B (B-high to B-low): 4.8 ohms (out of spec)
A-high to B-low: 5.1 (should be infinite)
B-high to A-low : 51 ohm (should be infinite)
A-high to B-high: 52.2 (should be infinite)
A-low to B-low: 4.1 (should be infinite)
Old Aug 30, 2009 | 08:45 AM
WS6HUMMER's Avatar
Good info for BS3 owners!
Old Sep 2, 2009 | 06:15 AM
Fireball's Avatar
Shawn is a certifiable perfectionist...
When he got my injectors...they were 12% variance from low to high. After his magic touch...he got them within 2%...but that wasn't good enough for him
he gave them to a specialist he knows to try to get them down to 1%
Got my BS3 back yesterday...they were even nice enough to tape the blown chips to the box haha
Old Sep 2, 2009 | 01:12 PM
  #32
427's Avatar
427
Hang the chips from the mirror!!
Kurt
Old Sep 2, 2009 | 01:18 PM
  #33
Fireball's Avatar
Kurt
haha...they are pretty small...
Old Sep 2, 2009 | 03:15 PM
  #34
LS1Tech Co-Founder
It's not how big they are son....
Old Sep 2, 2009 | 03:23 PM
  #35
DanZ28's Avatar
Wow, 13% . Glad I went the route I did.
Sounds like you got it figured out though, hope to see that 7 sec pass soon...
Old Sep 3, 2009 | 05:49 AM
  #36
Fireball's Avatar
they are small...but very important
Old Sep 3, 2009 | 06:14 AM
  #37
Krazy98Z28's Avatar
How soon before your testing?
Old Sep 3, 2009 | 06:41 AM
  #38
Fireball's Avatar
hopefully 2 wks.
Old Sep 3, 2009 | 05:59 PM
  #39
obZidian's Avatar
Get ir' done!!
Old Sep 3, 2009 | 09:54 PM
  #40
427's Avatar
427
It's not the size of the chip, but the magic in it!
Kurt
