blowoff valve ?
Old Nov 26, 2003 | 09:50 PM
Blown Ta's Avatar
Default blowoff valve ?
hey guys i am new to the board
i have a question. can i use the vortec race bov on a procharger 5 psi
i am ordering the kit i 2 weeks.also where does the bov mount
thanks in advance
Old Nov 26, 2003 | 10:20 PM
black_yukon's Avatar
From my limited experience with my Procharger, I noticed that the stock Procharger bypass valve works differently than bov's. The Procharger BPV, remains open under vacuum like when the engine is idleing. It takes very little vacuum to keep it open. Most BOV's that I have seen remain closed at vacuum and only open during vacuum spikes, like when the throttle closes abruptly. How would this affect performance if you switched... I have no idea. Maybe someone who has tried this will chime in.
Old Nov 27, 2003 | 07:52 AM
2001WS6Vert's Avatar
My car surges if I let off the gas while cruising at highway speeds. Will a BOV help with this? I have the stock BPV on now.
Old Nov 27, 2003 | 09:30 AM
If your vortech came with the stock valve, the little black plastic one, then I believe it is a BOV that is re-routed to the intake. That is the same Bosch unit that comes stock on turbo'd VW's, Audi's and Porsches. From what I've read on those sights, a lot of those guys are upgrading to bigger or more efficient BOV's to vent the air better.
As far as venting the air, it depends on your setup. If you BOV is before the MAF, then it should be okay. If it is after, then it should be vented back.
Old Nov 27, 2003 | 09:33 AM
Packy's Avatar
I just want one that is loud as hell! LMAO!
Old Nov 27, 2003 | 06:57 PM
Blown Ta's Avatar
i want one becouse they sound cool
but i dont know if its ok to use with low boost
i am only going to run 5 psi for now
