Idle Characterists of 0" of Vacuum
Old Sep 3, 2009 | 10:01 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Idle Characterists of 0" of Vacuum
Wondering about what the title says.....
Old Sep 3, 2009 | 10:12 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
They rattle a lot and require diesel fuel. Some have no rattle, but require JET A, very similar to kerosene. What is your question.
Old Sep 3, 2009 | 10:19 PM
ls1290's Avatar
Did you read the title.....
Old Sep 4, 2009 | 01:00 AM
DeltaT's Avatar
Isn't that just ambient air, like maybe a motor that is shut off?
Jim
Old Sep 4, 2009 | 01:09 AM
SilverSS's Avatar
Probably would be lumpy as hell but I doubt the motor could run on its own? Why do you ask?
Old Sep 4, 2009 | 06:20 AM
engineermike's Avatar
If it truly had 0" of vacuum at idle, then cracking the throttle open would make no difference at all.
Old Sep 4, 2009 | 05:06 PM
DeltaT's Avatar
Right, it's a motor that isn't drawing any air, or its idle speed is also its WOT speed which is unusual to say the least.
Jim
Old Sep 4, 2009 | 05:33 PM
98Z28CobraKiller's Avatar
Restricted User
Looks like maybe a trick question. 0#'s of vacuum is no vacuum or 101 KPa. 0" inHg is 14.7#'s of vacuum or 0 KPa.
Old Sep 4, 2009 | 06:42 PM
67Firebird455's Avatar
It wouldn't "idle".
Old Sep 4, 2009 | 06:59 PM
ayousef's Avatar
ok so no restriction from a throttlebody, and something else controlling the engine speed electronically lol.
Old Sep 4, 2009 | 07:20 PM
KILLER-LS1's Avatar
no i think he means a supercharger putting out enough boost at idle to make 0 psi instead of vaccuum like a turbo or smaller supercharger would have at idle.
Old Sep 4, 2009 | 07:45 PM
No, because if 0 psi got into the intake plenum, it wouldn't be at idle any more.
Old Sep 5, 2009 | 01:35 AM
SilverSS's Avatar
Maybe his cam is so big it would have no vacuum
296/299 .868 .976 099lsa
j/k!
Old Sep 5, 2009 | 01:23 PM
Restricted User
Maybe he just has a bad MAP sensor. LOL
