Kaboom
Old Sep 25, 2009 | 09:37 AM
Gordon0652's Avatar
That should not have happened...
Whats the power it was making? Never seen a piston disappear like that before!
Old Sep 25, 2009 | 12:55 PM
HUNTER02SS's Avatar
What oil pan you using??? This is the same thing that happened to my old motor. Stock pan starved it for oil and it ate the front rod bearings and BOOM, broke it all to hell just like your did! Hate to see it happen. Are you going to make the shootout still?
Old Sep 25, 2009 | 01:15 PM
venom ws7's Avatar
Originally Posted by koolrayz
There was no detonation. The plugs are like brand new. When the piston got busted it opened that chamber and pushed a **** ton of aluminum into the intake. It then went through all the other chambers. There were pieces of ring and piston in some of the chambers. There was oil all the way up to the intercooler and chunks of aluminum laying against the throttle body. I had made about 15 passes with the same boost and tune and checked the plugs 3 times, the engine never pushed any water at all. It was a very soft tuneup.
Good thing you found the plugs after this
Sorry abou the carnage man I think the stock LS1 Record is mid 9s right??
Old Sep 25, 2009 | 01:24 PM
koolrayz's Avatar
Dont know. I will have the car running just dont know if a want to make the trip and not be able to run the number for the 9.0 index. I could run the 10.0 but it's not what I had in mind.
How is your hooptie doing? havent heard anything in a while?
Old Sep 25, 2009 | 08:34 PM
elias_799's Avatar
that suck man
love the husky ratchet you got in the picture
Old Sep 25, 2009 | 10:32 PM
Reject's Avatar
what a pimp!
