Most boost on pump gas
Old Oct 3, 2009 | 12:21 PM
detroit_903's Avatar
Default Most boost on pump gas
What's the most boost I can run on pump gas 94 octane. 383 stroker 9.2 compression vortech t-trim. FMIC Intercooler ONLY
Old Oct 3, 2009 | 03:03 PM
stevieturbo's Avatar
depends how restrictive your engine is. But Im sure you can safely spin that blower as hard as it will go without too much worry.
Old Oct 3, 2009 | 03:48 PM
elias_799's Avatar
i would say you can get 13 psi out of it, i would personally get some meth if you go over that boost level.
Old Oct 4, 2009 | 03:26 PM
cfon159's Avatar
assuming:
botom end is forged
coolant is 180-200
timing retarded accordingly
afr is 10.5-11.0:1
intake temp is proper (intercooled)
aluminum heads
i would assume about 15-20 max before using race fuel to prevent detonation/knock or alchy/meth injection to allow cooler charge. this is also before humidity/barometric pressure/altitude come into play. also more along turbo specs but should be relatively equivilant.
*not 100% certain, just educated guess. im sure someone may disprove me...
Old Oct 4, 2009 | 03:35 PM
Im using 9.5:1, 20psi/YSi and pump fuel. Runs fine if you dont be greedy with timing ( which I always was before lol )
