130 miles from one tank
Old Oct 12, 2009 | 09:56 AM
02NBMFormula's Avatar
Originally Posted by elias_799
but thanks for being an *******.
i laughed at that.
what gears do you have? that isnt bad but it seems like it could be better. with the 4l60, stall and 3.23 i would get about 150miles to 1/4 tank.
maybe that low compression is hurting it
Old Oct 12, 2009 | 10:23 AM
ddnspider's Avatar
i do not need a wide band to tell me if my car is running rich, i just occasionally check the spark plugs after a wot run. but thanks for being an *******.
Hey genius, you cant check your spark plugs in the middle of a pull.If your pump starts failing or an injector starts to get pluged or something else happens you wont know until after you blow something up
Old Oct 12, 2009 | 10:55 AM
The Fugitive's Avatar
I will agree that it is just wise to have a wideband, you don't want to be in a wot pull and go lean. But I have 3.73 gears and I get about 170ish at the 1/4 and I have a really heavy foot. damn boost is so much fun....oh back on topic yeah I would get a wideband to see what it is at cruising but how bad is the stop and go that could be it also?
Old Oct 12, 2009 | 11:10 AM
black98ws6ta's Avatar
Eventhough sic lsx might have not said it in the best way, he was completely correct. There is not a good reason for not having a wideband on the car, it is very cheap insurance. It would also help diagnos this problem.
Old Oct 12, 2009 | 12:12 PM
SIC LSX's Avatar
Sorry for being so rude about it. But reading plugs isnt that accurate.
Old Oct 12, 2009 | 01:15 PM
rod442's Avatar
Thats way low. With my new motor and partially tuned 60# injectors I got 200 miles on the 1st tank and 230 out of the 2nd tank with a 1/4 left. about 50% highway. Its really rich at cold startup, not so bad on hot cruise.
I'd say something's off.
Old Oct 12, 2009 | 08:33 PM
elias_799's Avatar
i guess ill be getting a wideband thanks for the tip SIC LSX, i have all the time now since i put my car away for the winter. how much a wideband cost anyway ?
Old Oct 12, 2009 | 08:37 PM
elias_799's Avatar
Originally Posted by 02NBMFormula
i laughed at that.
all of the driviline is completely stock have no idea how it held up to all those 12.1 passes
Old Oct 12, 2009 | 09:03 PM
SIC LSX's Avatar
I paid $200 shipped for my AEM wideband of ebay! I have used a few others and like it the best! It the best bang for your buck!
