meth nozzles
Old Oct 12, 2009 | 11:52 AM
The Fugitive's Avatar
Default meth nozzles
do they go before of after the IAT sensor? How far away should I put them?
Old Oct 12, 2009 | 01:51 PM
black98ws6ta's Avatar
Before the IAT so you can see and tune for the change in intake air temperature. 3-4-5 inches would be good if you have the room.
Old Oct 12, 2009 | 06:41 PM
great421's Avatar
Default 2x vote
Yep.
That's where mine is.
Old Oct 12, 2009 | 10:15 PM
Thanks guys for the help, how would I run dual nozzles and how far apart should they be?
Old Oct 12, 2009 | 10:34 PM
BLOWNBLUEZ06's Avatar
I run one on each side of the intake tube. Putting it behind the IAT sensor will allow you to create a meth reliant tune. If the meth quits for any reason, the computer will pull timing and help save you from damage. IAT vs. Spark is the table in HPtuners. Log the car and see where your IAT's are with the meth, at WOT for a good pull. Then put the threshold at the next increment above that to pull timing in the boosted region of the table.
Old Oct 21, 2009 | 05:46 PM
vipvegas's Avatar
If running dual meth nozzles the say 180 degrees from eachother in the pipe, same distance from IAT
