STS warning buzzer
Old Oct 12, 2009 | 05:56 PM
charlie c5's Avatar
Default STS warning buzzer
I have my boost turned down to 4 lbs. And when I get into it my warning buzzer buzzes. What the hell. Im not running the STS PVC valve, I have my valve cover vented to the atmosphere. Any ideas as to why my buzzer buzzes. Oh yeah I did remove the little gold resistor and hard wired it..
Thanks guys..
Old Oct 12, 2009 | 06:25 PM
hawk584's Avatar
the buzzer is an oil pressure warning alarm. either to high or two low and it will sound. my guess would be not enough oil pressure. do you have a high/ low switch? if so, flip it to high and leave it alone. and check for oil leaks
Old Oct 12, 2009 | 06:38 PM
great421's Avatar
Default Buzzer = BAD!
Thanks guys..
The warning buzzer is an indicator that the oil pump not working when the engine oil pressure exceeds 1 psi at the pump - so this is bad. It means that the pump is not pumping oil back to the engine, as designed. I had a relay go bad, so it would not supply current to the pump; I replaced the relay, problem solved. Check those relays, it may be something simple as that...
Old Oct 13, 2009 | 01:22 AM
charlie c5's Avatar
Sweet, Ill check the relays. I dont have the "High / low" pressure switch. The pump runs on high all of the time. I havent had any oil leaks.
Old Feb 24, 2010 | 09:33 AM
vipvegas's Avatar
any updates?? Having the same issue with my new setup. Funny this is the second issue Ive had that duplicates yours charlie.
Old Feb 24, 2010 | 10:41 AM
Zombie's Avatar
caused by pressure in line under boost. Just adjust the hobbs switch higher.
Old Feb 25, 2010 | 05:38 AM
OUTLAWZ RACING's Avatar
If its a sts pump u can adjust it by turning it clockwise to increase the tq on it. I done it befor. billy at trt told me to do it ages ago.
