2 step and Procharger??
Old Oct 18, 2009 | 10:17 PM
LS1RedZ's Avatar
Default 2 step and Procharger??
Just wondering who on here is using one at the track and how much it helps. Will it build boost to whatever you have it set at correct (engine rpm)? Just like a turbo? Car is a 6 speed too.
Old Oct 18, 2009 | 11:30 PM
1INSANEGTO's Avatar
Ummmm No I don't think so... but I am sure the method for building boost by a turbo vs supercharger is totally different.
experts will answer
Old Oct 19, 2009 | 01:12 AM
bondosgto's Avatar
Old Oct 19, 2009 | 01:26 AM
ninetres's Avatar
Being that prochargers build boost by RPM, I would gander that setting the 2-step at a particular RPM will yield that level of boost upon release of the Tbrake or clutch.
Old Oct 19, 2009 | 02:00 AM
blue00ZZleeper's Avatar
Also as someone pointed out to myself before their good for consistency and when you leave with just throttle your not at 100%, your at whatever it takes to hold it there. With the 2 step, it regulates to a set rpm but it is a 100% throttle.
Old Oct 19, 2009 | 02:11 AM
kmracer's Avatar
no, it wont help build boost at all. a supercharger is driven by the engines belt, the only way to build more boost is with more rpm's.
it'll help you be alot more consistant though, launching will be alot easier.
Old Oct 19, 2009 | 03:06 AM
Blown06's Avatar
8 Second Truck Club
Prochargers need engine load to build boost, not just rpm. I'm guessing that since your a 6 speed car it will not build boost because you will have the clutch in and the motor won't be against a load, no matter what the throttle position is at. Procharger and 2 step on an auto trans will build boost given enough rpm because the motor will be fighting the tq converter.
Old Oct 19, 2009 | 03:28 AM
ninetres's Avatar
Wouldn't the boost come in as soon as the clutch was released? Kinda instantly?
Old Oct 19, 2009 | 03:42 AM
Blown06's Avatar
8 Second Truck Club
Yea it would but that has nothing to do with a 2-step. Which is what the original poster was wondering. If he is looking for consistancy then yes the 2-step will help. But, regarding boost, whats the difference in droping the clutch with or with out a 2-step given the same rpm? I say nothing, as your going full throttle immediately anyway.
Old Oct 19, 2009 | 09:49 AM
kp's Avatar
kp
Superchargers dont need load to make boost, thats a turbocharger. The bypass has to be closed though, with a M6 car at WOT the bypass should be closed if its adjusted properly.
At 2800rpm on the 2 step with the D1SC I see 2-3psi, with the F1A I used to see around 5psi at 3000.
With a manual trans drag car its a bitch to hold it at a certain RPM pre-launch. 2 step is a must have if you drag race a lot, I run the same off the foot brake and 2 step so having that little bit of boost doesnt make much difference in ET really. But its a lot more consistent when you just have to hold the pedal to the floor at the line and not look at the tach.
Old Jul 7, 2010 | 10:41 AM
LSXFORMULA99's Avatar
what two step is best for the procharger? msd or lenginfelter
Old Jul 7, 2010 | 01:57 PM
LS1RedZ's Avatar
My thread has RISEN!!! lol.. Im thinking about going with the MSD. Seems easy to plug in and use.
Old Jul 7, 2010 | 11:02 PM
I like the LPE. I helped tomz28 set it up in his car and it was easy and worked great. I plan on running the same one. Need to find the right rpm to set her at though. Start at 3k and go from there I guess lol
Old Jul 8, 2010 | 12:07 AM
I_Need_Land's Avatar
http://www.streetfire.net/video/lt1-...aro_729473.htm
6 spd, d1sc, 2 step. like 2300rpm or so
Old Jul 8, 2010 | 09:06 AM
what kind of two step is that?
Old Jul 8, 2010 | 09:41 AM
Aetos's Avatar
Another good thing about a 2-step on a manual car connected to the clutch is it makes powershifting easier/safer. You can hold your foot on the throttle, press in the clutch, and shift without worrying about over revving the engine. The 2-step will stop your rpms from constantly redlining while the clutch is down. It also takes torque load off of the drive train allowing the shifting to go in easier.
Old Jul 8, 2010 | 10:01 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Cool, I see you did get a new Shelby Mustang! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
