BOV mounting
Old Dec 7, 2003 | 04:27 PM
Blown98's Avatar
Default BOV mounting
Soon im going to buy the turboXS H-RFL blowoff valve, does anyone else have this one? if so how do u have it mounted, what did you have to change if any, does anyone have any pics i could use as guide lines? thanks
Old Dec 7, 2003 | 05:28 PM
black_yukon's Avatar
What is the setup you have right now? What BOV do you have right now?
Old Dec 8, 2003 | 01:31 AM
Blown98's Avatar
i have a vortech but im not sure which one, im running 9.5 psi and using the Bypass valve it came with.
Old Dec 8, 2003 | 01:37 AM
Blown98's Avatar
im prety sure i have the S-Q one i think
Old Dec 8, 2003 | 08:09 AM
If you are running the little black bosch valve, then it is the same valve use in turbo'd VW's, Audi's and Porsches. I believe the tube size on those is 1". If you want to find and easy drop in solution, I recomend you find an aftermarket BOV made to fit those cars. Check www.blowoffvalves.com. Most of BOV's are universal fits, but will have an adapter kit to suit specific vehicles. Look for and Audi adapter kit.
