A/A intercooler to support 1000rwhp? Will eBay 4" unit support this....
Here's a pic:
My car weighs 3500lbs, runs on pump gas and meth, and has a run a best of 9.1@155.
My IAT temps in 95 degree heat is around 85 degrees at the end of the run, in cooler temps it's around 75-78 degrees.
I'm using a Alky Control Meth kit running a #10 and #15 nozzle.
The Treadstone cores seem to work really well for me.
I did consider a core like that for mine, but I just couldnt get my head around how it could possibly cool enough.
With my previous setup, after a quick 3rd and 4th blast, temps would rise from say 72degF at the start, to 125degF at the end. Thats only a few seconds, say 6-8 seconds or so.. Thats on the road, IC core only, no meth. A large temp increase really, showing the IC is pretty bad at its job.
When racing I always used meth, so it doesnt give any valid data about whether the intercooler is any good or not. With the meth on, temps did usually drop ( although they did still increase a bit when racing, but not much.
With this new core, 24" tubes, 4.5" thick and 15" tall.
At the start of a run, IAT's were about 61degF ( was a cooler day ), at the end of the same 3-4 run, temps were a much better 90degF
Massive improvement over old.
I havent actually done any racing/logging with the new core apart from some road use. Havent tried it at all with meth yet.
Fit as big, and the best core you can afford and physically fit in the car
The problems may arise if you need to access that power, over longer periods of time, when innefficiences with the actual cooloing ability may crop up.
If you intend to use high power, for extended durations, then thats when the intercooler must perform.
I doubt the cxracing A2W is good to 1000hp. That's what they rate there A2A is rayed for. I'd bet it'd be about the same.
Methanol adds energy to the mix though, as its also a fuel.
Once it boils, it cant remove any more heat ( as far as I remember lol )
As methanol boils at a much lower temperature, it has less ability to remove heat.
