What block to run for FI
Old Nov 3, 2009 | 09:20 PM
427's Avatar
427
The LQ9 should swallow the 4.00 stroke without work on the block unless you use a rod that is bulky on the big end. The 4.125 stroke may need some minor work, but you should not pay more than 150$ for that.
Kurt
Originally Posted by Devils Mentor
I just spent 45+ mins searching for the avg price on clearing a block for a stroker kit. Does anyone have a ballpark estimate on working a LQ9 for a 408 or 416? And before anyone rants... I know all shops are different, hence the reason I said "ballpark"
DM
Old Nov 3, 2009 | 09:53 PM
elias_799's Avatar
Originally Posted by Shawn @ VA Speed
i would stay away from ls1 blocks,they are not nearly as strong as the others
can you tell us why ? i have a forged 347 and my goal is 800whp. you think the block will take a dump ?
Old Nov 5, 2009 | 07:53 AM
Devils Mentor's Avatar
Kurt
How does the LQx take to a 416 stroker? Is it too much for the block?
DM
Old Nov 5, 2009 | 11:36 AM
427's Avatar
427
That is subject to different thoughts. My thoughts are the cylinder in the iron block is pretty short for using the 4.125 stroke although it can be done. If you decide to try this, the proper piston will be what makes or breaks the deal. I would contact Brian Nutter at Wiseco as he seems to have a good handle on skirt design that can work in this type of engine build.
Kurt
DM
