boost sensor for LM-1
Old Nov 9, 2009 | 06:53 AM
forcd ind's Avatar
Default boost sensor for LM-1
i would like to try and log my boost on my LM-1, i need some kind of sensor that would work, i know the rpm converter only will take 0-5 volts
i run a carb, and have one of the Autometer mech. memory setups(boost), but it only shows the highest boost, and it is always getting dirt or something in it, and leaks down-i can log like 5 items on the rpm converter, would be cool to
see it all overlayed when i download it-right now it just shows AFR's and RPM's
Old Nov 9, 2009 | 08:29 AM
stevieturbo's Avatar
Just buy a GM 3 bar map sensor. That'll allow you up to 29psi boost.
Old Nov 9, 2009 | 09:02 AM
camarols1's Avatar
The Auxbox module made by Innovate Motorsports is a plug-n-play solution for this.
It will log rpm, boost, and even acceleration into one file for you to view in your existing LM1 Logworks software.
PM sent!
Jim
