Tru boost setup help
Old Nov 11, 2009 | 09:57 AM
dreamls1's Avatar
Default Tru boost setup help
Alright, how the heck do you program this thing? I read the manual but it sux! I am sick of running off the spring because of the inconsistent power. I want to set it where i am running 12psi all the time! Is there a write up somewhere how to program this or can someone help me out?
Old Nov 11, 2009 | 01:26 PM
pwrtrip75's Avatar
Wouldnt running off the spring give you the same boost all the time? It does for me and its very consistent.
Old Nov 11, 2009 | 02:53 PM
dreamls1's Avatar
nope, not with mine. I have quite a bit of creep.
Old Nov 11, 2009 | 09:52 PM
pwrtrip75's Avatar
wouldnt your wastegate be too small then? How would a boost controller correct that?
Old Nov 11, 2009 | 10:31 PM
ls3s10's Avatar
i have one of these you can set it a psi only a wastegate duty cycle , start at 10% and work your way up it holds mine just fine, make couple passes and up it correct pressure, hold both buttons 2 secs and then hit left button and set a setting to a10 and hit both buttons until it says run,
