Critique my turbo setup please!
Old Nov 15, 2009 | 10:16 PM
SKINNY69's Avatar
Originally Posted by XtremeDime
What would you suggest? Another member on here did a full write up and had great success with it. I suppose I could run 1 port off each valve cover to the exhaust which would create a constant vacuum in the crank case. Is that better?
There's many different ways to go about it but generally you can only pick one method to vent the crankcase. A lot of guys just vent through filters, while others choose to outsource vacuum from the intake, exhaust, or pumps.
I've always liked the idea that a crankcase under vacuum frees up HP so I've always went that route. I see guys spending thousands on vacuum pump setups but I prefer to source vacuum pre-turbo with a baffled catch can. It's cheap and the vacuum is constant. The exhaust evacuation system looks pretty solid but I've never used it so I have no input.
Old Nov 16, 2009 | 01:08 AM
XtremeDime's Avatar
So youre running a dual catch can(1 from each valve cover) with the vacuum source pre turbo?
Old Nov 16, 2009 | 02:15 PM
XtremeDime's Avatar
Ordered my springs and rods today!
