Putting Together ProCharger Front Mount
For the couplers at the TB and at the supercharger outlet I got from Silicone Intakes since they weren't included in the ebay kit. I also had to get the aluminum pipe for the bypass valve and also had my machinist make a flange out of aluminum. (Procharger makes an aluminum flange, but it was handy to have one made locally since he gives me a good rate with the other work I give him.)
I spent almost $700 having mine put together in parts plus paying a buddy to weld the aluminum for me. I measured, cut, and mocked up the piping myself. That is including the intercooler, piping, couplers, clamps, and ATI race bypass valve. If you can find a good deal on a used valve or can weld the aluminum yourself you might get away a little cheaper, but for the time spent if you don't have the tools to do it yourself it adds up quick in labor.
It could have been done much cheaper if I didn't go with new pieces and a less expensive bypass valve.
Oh I forgot to mention you will need a threaded IAT sensor, I think you can look it up from a GMC Syclone I don't remember the part number off hand but could get it if you need, and a bung for it. I got my aluminum bung from McMaster-Carr, part # 44705K318.
Realistically EPP's setup is pretty well priced. I spent almost $700 having mine put together in parts plus paying a buddy to weld the aluminum for me. I measured, cut, and mocked up the piping myself. That is including the intercooler, piping, couplers, clamps, and ATI race bypass valve. If you can find a good deal on a used valve or can weld the aluminum yourself you might get away a little cheaper, but for the time spent if you don't have the tools to do it yourself it adds up quick in labor.
The Ebay stuff that I have seen is pathetic.
The above two pieces of silicone blew apart at just 10 psi on an STS Camaro we built. Once it had a hole in it, you could tear it apart like a piece of paper!
Bob
Chad, I agree, not counting the Bypass valve, 400 isn't a bad deal for putting it together oneself. I hear you there on selling the old kit, the twin 4.5" system paid for my front mount.
One of them was at the intercooler. Bob
The only ones that aren't is the 4" to 3" reducer at the throttle body (4 or 5 ply bought from silicone intakes) and the 45 degree bend from the supercharger outlet, also beefy from the same place.
That is one of the nice parts of your system is that all the couplers and clamps are of good quality. I had the opprotunity to take a look at one about a month ago helping someone change out their bracket. The fitmet of everything looked pretty good. The only lament was the hard pipe was steel so he had a few rust spots.
Supplied Parts MAF Kit 1 - (12”x 24”x 4”) Intercooler 3 - 3 x 3” Silicone hump hose 1 - 3” Silicone double hump hose 1 - 4” to 3.5” 90 deg Silicone Elbow* 1 – 3.5” to 3” Silicone Reducer* 1 – 4.25” T-bolt Hose Clamp* 2 – 4.00” T-bolt Hose Clamps* 9 – 3.00” T-bolt hose clamps 4 - Intercooler supports 1 – IAT Sensor Speed Density Kit 1 - (12”x 24”x 4”) Intercooler 3 - 3 x 3” Silicone hump hose 1 - 3” Silicone double hump hose 1 – 4.0” 90 degree Silicone Elbow 1 – 4.0” to 3.0” Silicone Reducer 1 – 4.0” Coupler 3 – 4.00” T-bolt Hose Clamps 9 – 3.00” T-bolt Hose Clamps 4 – Intercooler Supports 1 – IAT Sensor
