Question porting heads
Old Nov 18, 2009 | 12:35 PM
sujomatt's Avatar
Default Question porting heads
I know that boost is actually a measure of resistance, etc. So I am thinking - I should probably work on getting this car to flow better.. Already have a Fast 78mm intake manifold, EPP FI Cam, and the restriction I feel is probably in the 317 heads.. Would it really be worth the work to do the porting and avoid changing the valves? Any idea of gains vs how much less boost, etc. Or anyone have experience, know of costs, etc in getting this done at a machine shop? I am probably doing a bottom end soon, thinking of keeping it a 346 or maybe 402, so any input is appreciated. Thanks!
Old Nov 18, 2009 | 02:15 PM
stevied916's Avatar
your best bet is to leave the runners alone, get a bigger exhaust valve and intake if you want (intake isnt as important) and blend the bowl
Old Nov 18, 2009 | 04:49 PM
OUTLAWZ RACING's Avatar
560 is dam good on a stock bottom end, I run a set a patriot stg 3 heads with the bigger valves. The good news is with a 370 or 402 and a 76 gts and 14 psi you would be in the mid 700 hp range on the patriot heads. They not expensive either. I think u can send your 317 to them and they can also hook them up.
How dose the car run I bet it screams with that cam lol.
Old Nov 19, 2009 | 08:48 AM
sujomatt's Avatar
Yea its like turning beast mode on lol - im wicked happy with it.. i cant believe i had a stock cam in this thing in the first place haha
Old Dec 4, 2009 | 10:57 AM
solo21's Avatar
I had the same question as far as the porting...SUJOMATT, did you find someone that does porting? if so what kind of prices did you run into?
