Fuel Pump
Old Nov 20, 2009 | 08:42 PM
SSClone's Avatar
Default Fuel Pump
Helping a friend install a turbo setup on a 99 SS(my old car) and we are trying to figure what size fuel pump to install. A little about the car, it is a 346 with ARP rod bolts and head studs, has ported 317's, cam is a little over .600 lift on a 116 lsa. He's using an Edelbrock carb style intake with elbow and a 90mm tb. The turbo is a Garrett 70mm and he's using 60lb injectors. What would be best?
Old Nov 20, 2009 | 08:47 PM
speedsk899's Avatar
a walboro 255 should be able to handle that. If you want to be safe put in two
Old Nov 21, 2009 | 12:12 AM
TurboZ28408's Avatar
that turbo, that fuel pump with an aftermarket fuel regulator i ran 669WHP with a tubular front facing turbo setup
Old Nov 21, 2009 | 02:15 AM
LS1Silverado05's Avatar
+1.. 2 is cheap insurance
