Need bov help
Old Nov 30, 2009 | 07:26 PM
1_bad94Camaro's Avatar
Default Need bov help
Like the title says I need help sizing bov's for my 6.0 setup. the setup is twin 57mm turbos on a 6.0 iron block LQ4. I want to run 8-10 pounds of boost if possible.
Thanks in advance.
Steven.
Old Nov 30, 2009 | 07:39 PM
Dean95z28's Avatar
I would say JGS 40mm units would work perfect for you. Also they are very affordable. Contact Modular Turbo for a good deal on them! The spring that is in the wastegate is a 7lb spring and they also come with a 10 lb spring. I love mine no creep at all.
Old Nov 30, 2009 | 07:43 PM
So I would need 2 bov's with 7lb bov's correct? or the 10lb?
Old Nov 30, 2009 | 07:45 PM
XtremeDime's Avatar
I think you are confusing wastegates with blow off valves.
Old Nov 30, 2009 | 07:47 PM
any and all information is appreciated. I'm pretty new to turbos and sizing is what really gets me.
Old Nov 30, 2009 | 07:51 PM
Dean95z28's Avatar
Sorry I miss read your post. You only need 1 BOV and I like the JGS 56mm unit. It is a awsome piece and is around $250
Old Nov 30, 2009 | 07:59 PM
oh ok awesome. as far as wastegates there is 2 38mm wastegates coming with my turbos. will those be enough or will they be too small?
Old Nov 30, 2009 | 08:40 PM
XtremeDime's Avatar
2 38mms should be fine if you want to run atleast X amount of boost all the time you need a spring a littler lower than X. The spring basically provides the minimum amount of boost you can run ie you cant have a 10psi spring and want to run 8.
Old Nov 30, 2009 | 08:42 PM
oh ok. so if i want to run 10 pounds I would need 10lb springs in each wastegate correct?
Old Nov 30, 2009 | 09:26 PM
XtremeDime's Avatar
Im not sure on a twin setup, I would imagine the pressures would be combined so 2 WGs at 5 psi would probably equal 10psi(I would say closer to 9ish). But im really not 100% on that one...
Old Nov 30, 2009 | 09:31 PM
thanks bro. I'm still doing research while i'm putting the motor together. Hoping to have the truck fabbed and on the street with the turbo's early feburay.
Old Nov 30, 2009 | 10:30 PM
XtremeDime's Avatar
Dont take my word for it though on the twin setup lol im just postulating since no one else is chiming in
Old Nov 30, 2009 | 10:54 PM
black98ws6ta's Avatar
Yeah it works the opposite of what you said. If you want to run 10 psi then you want twin 10 psi springs. Each gate works seperately and they will have a combined pressure as a reference. Where you reference the gate will change it alittle bit, but get the spring that is the base pressure you want to run.
Old Dec 1, 2009 | 02:56 PM
Oh ok. much more understood now. I'll be checking the springs when they come in to see which ones they have and if need be i'll get diffrent springs.
