Tbss w/tvs question
Old Dec 1, 2009 | 11:53 AM
Teamscss.com's Avatar
Default Tbss w/tvs question
A quick question...
I have an 07 TBSS 2WD (all stock) with magnacharger TVS 1900 currently with a 3.3" pulley on front, and stock rears. Will a 2.8" pulley generate 10psi? If not, than which one?
I know psi is relative to the rest of the engine mods, so here's the rest of it.
Being installed today are Kooks 1 3/4" LT w/high flow catted y-pipe, Magnaflow 3" single side exit exhaust, and a meth kit.
Search didn't yield me any results.
Thanks,
Abo
Old Dec 1, 2009 | 12:39 PM
old motorhead's Avatar
After you have the mods all done, see how much boost you have with your current pulley. Call Brian, at Magnacharger, and tell him where you are and where you want to be boost wise. He'll get the pulley right the first time. You will probably have enough back pressure in your exhaust system to hit 10psi with the 2.8 pulley. Brian will know for sure. With true duals, your boost reading would go down, but power would be up.
Old Dec 1, 2009 | 07:56 PM
Verified with Drew at Magnacharger that a 2.8 pulley will net 10 psi.
Thanks
