valve springs for boost.
Old Dec 1, 2009 | 08:21 PM
94dragbird's Avatar
Default valve springs for boost.
I seen in the sticky that patiot duals could be used but was wondering what everyone else uses. It will be stock bottom, stock cam, 317's and a D1sc with fmic set on 8# pulleys(I know, disaster waiting to happen). What are you guys with similar setups using?
Old Dec 1, 2009 | 08:22 PM
XtremeDime's Avatar
Im going to be running ls6 yellows @ 6psi with my turbo setup. Should hold me over until I have a forged motor :p
Old Dec 1, 2009 | 08:24 PM
94dragbird's Avatar
Yeah, a forged 347 is next on the list after the D1
Old Dec 1, 2009 | 10:52 PM
conan's Avatar
I have ferrea dual springs and stainless valves in my 317 heads.
Old Dec 2, 2009 | 02:13 PM
JAX04's Avatar
dont know how much truth there is to this statement, but i have been told by some locals that a set of stock springs on 241 heads will start to let loose after 7-8 lbs.....? like i said, dont know how much truth there is to this.
Old Dec 2, 2009 | 04:05 PM
OUTLAWZ RACING's Avatar
patriot golds dual for the last 3 years and have not floated them yet 15-18 psi
Old Dec 2, 2009 | 04:11 PM
52172's Avatar
Very true probibly start floating earlier like 5-6 lbs.
Old Dec 2, 2009 | 04:25 PM
hellbents10's Avatar
LS1Tech Sponsor
A fresh set of LS6 springs on a stock cammed centrifugal setup will make it too 8psi, I would run at least 1218 PAC springs though.
Old Dec 2, 2009 | 05:54 PM
VINCE's Avatar
Shorty Director
Must be nice!!! 2nd set of Patriot Gold Extreme's and I floated the first set and a set of the best springs that come with AFR225's.
Old Dec 2, 2009 | 06:19 PM
BIG_MIKE2005's Avatar
^^^Whats your set-up though?
Old Dec 2, 2009 | 06:35 PM
VINCE's Avatar
Shorty Director
1999 Chevy Corvette Fixed Roof Coupe
SW/BM 408ci w/AFR 225's 72cc
Patrick G 224/230 .609/.604 114LSA +2
TTi X kit with twin T3/T4's A/R .82
Old Dec 2, 2009 | 08:09 PM
elias_799's Avatar
^^ how much psi ?
Old Dec 2, 2009 | 10:24 PM
94dragbird's Avatar
I'm going to go with at least patriot dual gold's to be safe. I also heard that prochargers 8 psi pullies actually make about 10-11 psi. Any thoughts?
Old Dec 3, 2009 | 12:50 AM
haighter's Avatar
I would like to know the RPM and also the lifters you are using? Also are they shimmed?
Old Dec 3, 2009 | 07:03 AM
How much boost & how high are you spinning it?
That lift isnt too bad on that cam. You must be beatin the **** outta that thing to be blowin thru springs like that.
Old Dec 3, 2009 | 07:29 AM
icicleboy's Avatar
not to go offtopic, but does someone know the specifications for stock L92 valve springs?
Old Dec 3, 2009 | 12:08 PM
LS1BLKSS's Avatar
Banned Village Idiot
a buddy of mine has this set up with stock springs, 241 heads, around 8 pounds i think, he hasn't had any problems been with the set up for over a year now
Old Dec 3, 2009 | 09:51 PM
94dragbird's Avatar
Thanks for the opinions guys. I'll probably go with the patriot dual golds
Old Dec 3, 2009 | 10:05 PM
52172's Avatar
good choice you don't want to skimp on the valve springs..... Might even think of gettin the extremes just a little more doe. Might as well in case you decide to up the boost?
Old Dec 3, 2009 | 11:14 PM
94dragbird's Avatar
haha yeah... I'm going to try and keep it at 8 until I can forge the bottom end... I can get a replacement for cheap but don't care to pull an engine if I don't have too....
