20 psi Question
8 sec potential, 12 sec slip
Where are you from? (Is that octane rating R+M/2?) Also, 20psi doesnt exactly mean much. How much HORSEPOWER do you plan on making at said boost? What ci? list as much about your setup as possible please if you want accurate answers.
Yes it is 98 octane fuel and with that boost I plan making 700+RWHP and I said dont worry about the internals and ci or the tranny I am only asking can I the 98 octane fuel handle it with 9.5 comp ratio
are you going to spray or go turbo or both lol? Why do you keep starting all of these vague threads in different sections with no details on your setup? If you want help give more details on your setup. Out of all the threads you have started, I don't think anybody knows your setup, so how can you expect to get accurate answers. Fwiw at 9.5 compression 98 octane most likely won't be enough for 20psi, but again more details are needed to give an accurate answer.
No. Running twin 91mm turbos at 20 psi will make way more power than your desired goal, and i beam rods, and off the shelf diamond street pistons can handle. It will likely create too much cyliner pressure for 98 octane.
Like everyone said. Give a DETAILED description of your build if you want accurate answers otherwise our "advice" will be useless.
Your real measurement should be horsepower and torque.
I put down 650 RWHP threw my 4L60 which is close to 800hp est engine on only 9 psi on my 364 (9.5 to1) CR on 98 octane with no problems at all .So 20 PSI might be over kill to reach your HP needs? The less boost you run to reach your HP goals the better you are and is way easyer on your engine IMO and wallet in the long run LOL
