how to max out a p1sc
Old Dec 21, 2009 | 07:50 PM
pdasterly's Avatar
Default how to max out a p1sc
what pulley combo size for max boost?
Old Dec 21, 2009 | 08:34 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Define max boost.
Old Dec 22, 2009 | 04:44 AM
EPP's Avatar
EPP
A 3.4 pulley on the head unit can result in belt slippage due to a lack of belt wrap. I'd use a 3.55 pulley and have a one inch larger oversize crank pulley made for it. Bob
Old Dec 22, 2009 | 04:08 PM
youngrigo's Avatar
Im running a 3.0 6rib pulley on the P1 making 9psi and no belt slip
Old Dec 22, 2009 | 08:24 PM
Mr.Big's Avatar
last pulls we made with mine before going with the F1C were with a 3.4 8 rib and a 10% over crank pulley... see the graph below, to be honest I believe there was a little more left in it, not a bunch, but some...
Old Dec 23, 2009 | 04:12 PM
JC70SS's Avatar
mr big 787rwhp on a P1SC? nice!!
Old Dec 23, 2009 | 05:40 PM
Mr.Big's Avatar
it took a long time and many MANY changes to the setup to break the 750rwhp barrier, but with the right combo I believe the P1SC could support 800rwhp if being overspun...
Old Dec 23, 2009 | 10:22 PM
JC70SS's Avatar
well i am going with a 3.4 and a MMS crank pulley. The rest of my mods are similar to yours....just hoping for a 600rwhp mark.
Old Dec 24, 2009 | 04:29 AM
EPP's Avatar
EPP
Question
Wow, most people with the f body bracket system end up with belt slippage going with anything smaller than a 3.55 pulley. Something doesn't sound right with your set-up, a 3.0 pulley should make a lot more than 9 psi unless your cam has a lot of overlap, or you live up at a very high elevation. Bob
Old Dec 24, 2009 | 04:32 AM
EPP's Avatar
EPP
That should do it. Back in the day I had a D-1SC and with the stock 6.0 six rib crank pulley and a 4.0 head unit pulley the car made 7 psi of boost. Swapped out the crank pulley to the MMS crank pulley and the boost went up to 15 psi. Bob
Old Dec 25, 2009 | 02:34 AM
youngrigo's Avatar
z06 cam and the bay area, california (sea level). It made 6lb with the 3.4 and 468rwhp... This is full bolton car as well.
Old Dec 25, 2009 | 04:32 AM
elias_799's Avatar
or the belt is slipping
Old Dec 25, 2009 | 05:57 AM
EPP's Avatar
EPP
Question
You either have a boost leak, faulty bypass valve, filthy air filter or the belt is slipping. I'd make sure the bypass valve only has a slight airgap when in the closed position. My brother's LT1 P-1SC Formula has been at 9 psi since '02 when the kit was shipped from ProCharger. You have to get past the inactive pic's. http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
Old Dec 25, 2009 | 09:39 AM
Bad30th's Avatar
You need to spin it pretty good to max it out... I think max is like 62k RPM for the P1.
BTW, I have an MMS crank pulley for sale... $150 shipped...
https://ls1tech.com/forums/lsx-parts...0-shipped.html
...and a 3.2" 6-rib blower pulley for $40 shipped :
https://ls1tech.com/forums/lsx-parts...pped-each.html
I just upgraded to an 8-rib setup.
Cheers,
Rob (Bad30th)
Old Dec 25, 2009 | 11:42 AM
youngrigo's Avatar
Now you guys got me thinking.....
Old Dec 27, 2009 | 07:18 AM
EPP's Avatar
EPP
I'd check everything out. You can cap off the intercooler tubing at the throttle body, and at the blower, and pressurize the system by installing a schrader valve into one cap. Last year we had a new ProCharger GTO intercooler that was leaking boost at a missed weld, it happens. Bob
