317's
Old Dec 22, 2009 | 05:28 PM
1999 SS's Avatar
Default 317's
ive been searching around and cant get a 100% straight answer. if i have a stock 1999 ls1 short block with stock pistons and i install a set of 317's what will my compression ratio be. i keep hearing different numbers and guys telling me that it "should be about" this number but i cant get a straight up solid repeatable number. HELP
how much do i have to mill them to get to 9.5?
did you guys buy them new or used and how much did you pay for a set?
Old Dec 22, 2009 | 05:38 PM
XtremeDime's Avatar
9.5ish
Old Dec 22, 2009 | 07:47 PM
Boosted One's Avatar
I come up with 9.252 to 1 if you use head gaskets that are .051" thick and 4.065 bore. I'm assuming your pistons are .015" in the hole though. I think mine were close to .020" but my memory is fading fast!
If you need a set of 317s shoot me a pm. I ended up buying a set of Darts for my project so I have a pair sitting around.
Old Dec 22, 2009 | 08:00 PM
elias_799's Avatar
the reason why you are not getting straight up answers is becasue you do not give out any information
what headgasket are you planning on using ?
where the heads milled ?
was the block ever decked ?
Old Dec 22, 2009 | 08:03 PM
kkslds's Avatar
A stock 99 will have a bore of 3.90
Old Dec 22, 2009 | 08:09 PM
I used 3.898 for the bore size. Your bore size of your head gasket is always bigger and should be matched to the heads you are using and not the bore of the block. Otherwise you could be hanging the gasket into the combustion chamber of the head.
Frank
Old Dec 22, 2009 | 08:14 PM
kkslds's Avatar
Ic. Thanks for setting me straight on that
Old Dec 22, 2009 | 08:16 PM
No problem brotha!
Old Dec 23, 2009 | 08:32 AM
cjmatt's Avatar
With a stock ls1, stock 317s and lq4 head gaskets, you should be somewhere between 9.1-9.2
Old Dec 23, 2009 | 03:12 PM
1999 SS's Avatar
how much would i do i have to mill the heads to get to 9.5 or so?
Old Dec 23, 2009 | 04:24 PM
XtremeDime's Avatar
lq4 gaskets being the GM ones?
Old Dec 23, 2009 | 04:40 PM
sparkwirez06's Avatar
http://www.race-cars.net/calculators...alculator.html put in your info, get your answer.
Old Dec 23, 2009 | 10:33 PM
1999 SS's Avatar
the reason i ask this is ive heard people claim anything less then 9.5 cr will give you sluggish low speed performance.
Old Dec 24, 2009 | 07:35 AM
You would need the heads to be 69cc to get 9.55. roughly every .005 you mill with give you 1cc so you would have to go .015" I would not reccomend milling the heads. The decks are thin enough as it is. I think 98 heads are 68cc. But they don't flow as well as 317s or 243s.
