2 z06 cam
Old Dec 23, 2009 | 03:57 PM
pat1812's Avatar
Default 2 z06 cam
why do people want to run this cam with a turbo im doing a 5.3 turbo in my car was wondering if the cam change is nessesery and what are the specs on the z06 cam thanks guys
Old Dec 23, 2009 | 04:19 PM
sparkwirez06's Avatar
http://www.summitracing.com/parts/NAL-12565308/ here's the specs simillar to a turbo cam!!
Old Dec 23, 2009 | 04:27 PM
02NBMFormula's Avatar
it is not necessary but you will see some gains from it. the z06 cam is very mild and people have made good power off of it, plus, its cheap!
Old Dec 23, 2009 | 04:42 PM
pat1812's Avatar
Default 5.3
thanks guys would you be afraid of running a regrind it cost 145.00 to my door
Old Dec 23, 2009 | 05:11 PM
gnx7's Avatar
Just get a used Z06 cam '03+ I believe is the better one. They are billet and shouldn't have any issues buying it used.
The stock 5.3/6.0 cam stops making power in the upper RPM range and a cam change is needed. They are simple to swap out with the engine on a motor stand.
Look up Parish who did a 5.3 turbo setup in a little Ford Fairmont. It went mid 9's repeatedly with a Z06 cam, upgraded injectors, better valvesprings, and MasterPower T70 turbo.
With larger turbos and a built motor people have made 1000rwhp with the stock Z06 cam. It works and will have a stock idle.
Old Dec 23, 2009 | 06:02 PM
-Q-'s Avatar
-Q-
I'm looking for one myself if anyone has a used one for sale...
Old Dec 23, 2009 | 06:41 PM
MY99TAWS6's Avatar
Here are some comparisons with various z06 cams and to my gt7 which pretty sure is made by comp for lingenfelter. I got it used so for the price can't complain. Now two cams can have similar specs but still some differences in lobe rates, ramp rates..
