Max Intercooler CFM
Old Dec 17, 2003 | 10:15 AM
MEAN LT1's Avatar
Default Max Intercooler CFM
If I have a intercooler that flows a max of 2200cfm and then I mate it up with a D-1 procharger that flows a max of 1400cfm. Is it a good assumption that this intercooler will be a good match?.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448851241
Old Dec 17, 2003 | 10:57 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
2200 cfm and it has 2.5 inlet/outlets?
Old Dec 17, 2003 | 11:07 AM
MEAN LT1's Avatar
I I wondered the same thing, I guess I can have 3" end tanks put on?.
Old Dec 17, 2003 | 10:07 PM
Whistler's Avatar
Sawzall and Welder Mod
You don't need to change the end tank, you can just cut off the neck and weld on a 3 incher.
Old Dec 17, 2003 | 10:09 PM
MEAN LT1's Avatar
So am I right that the intercooler will work with the d-1?.
Old Dec 17, 2003 | 10:30 PM
Whistler's Avatar
There's no reason it shouldn't. I doubt as well it flows 2200 with 2.5 inlets/outlets, but since the core is 3" thick you can run a 3" I/O for sure.
The core is 25x10 but the tanks are on the top and bottom, so are you sure you can fit it?
Old Dec 18, 2003 | 12:10 AM
69firebird's Avatar
icw got one bigger than that in the nose of my ta, just have to be innovative with how you mount it
Old Dec 18, 2003 | 01:39 AM
scottywheels's Avatar
I still like the one from griffin better
Old Dec 18, 2003 | 07:39 AM
MEAN LT1's Avatar
Well, I decided not to take a chance on that intercooler but a spearco dealer did email me and let me know that he has a 3-core sheet metal intercooler that will trully support upward towards 1000hp. So I think im going to check that out plus it has the end tanks on the same side the way I wanted it in the first place. It will look just like the intercooler at the bottom except it wont be from ati and the quality will be better.
http://www.procharger.com/intercoolers.shtml
