Single O2 sensor
Old Dec 25, 2009 | 02:49 PM
poconojoe's Avatar
Default Single O2 sensor
I'm planing on using a 12200411 PCM and a 2001 / 2002 4.3 vortec tune converted to 2 or 3 bar, but the OS requires 2 O2 sensors. I'm using a set of Syclone manifolds and since these manifolds use a crossover pipe to get the exhaust from one side to the other. I can mount an O2 sensor on the drivers side of the crossover pipe to measure the driver's side, but the turbo mounts on the passenger side manifold, so if i put an O2 sensor on that manifold's output, it will be measuring both sides. The only alternitive
i see is to drill and tap the passenger side manifold for an O2 sensor further back, unless somebody knows how to shut off the bank to bank control
Old Dec 25, 2009 | 03:12 PM
elias_799's Avatar
you can tune for one sensor.
Old Dec 25, 2009 | 04:21 PM
poconojoe's Avatar
How?
HP Tuner or EFi Live?
