Fuse Blocks
Old Dec 28, 2009 | 09:09 PM
blazin's Avatar
Default Fuse Blocks
Hey im in the middle of a build of a twin car. I was wondering if anyone wants to share where they are moving the fuse blocks on the trans ams that is located on the drivers side behind the headlight? Pics would be great! Thanks
Old Dec 30, 2009 | 10:07 AM
Fireball's Avatar
I moved everything in the car...just takes ALOT of time...
No pics though
Old Dec 30, 2009 | 09:51 PM
The Fugitive's Avatar
has anyone thought about getting rid of the AIR box make 3 cuts under the fuse box and bending and making that a compartment for the fuse boxes or would that not work?
Old Dec 31, 2009 | 12:40 PM
Boosted 99 TA's Avatar
i also moved all of my wiring in the car. makes a lot more room and a cleaner look.
Old Mar 16, 2010 | 08:11 PM
blazin's Avatar
Anyone wanna share any info? I would like to run the wiring through the drivers side fender well like the wire tuck for the drivers side. All i know is i need to get those fuse blocks outta my way.
Old Mar 16, 2010 | 09:22 PM
1fast bird's Avatar
I moved mine into the wiper motor area. There is a ton of room if you don't run any wipers. You will just need to lengthen the wires to your lights up front which is not too bad.
