My 408 Turbo Build thread...
Old Jan 1, 2010 | 01:09 PM
Inspector12's Avatar
TT-TECH Veteran
I am sure you have already thought about it but the condenser will need ALOT of air going across it and I don't think the two fans you have in front of it will pull enough air to keep you from over presuring the A/C system unless you are moving possibly, just something to watch out for etc... But with that said it looks awesome. I see you lost your front swaybar, is that due to the turbo kit or just for drag racing etc...?
Old Jan 1, 2010 | 01:20 PM
koji777's Avatar
I"m probably gonna put a barrier between the condensor and the fans... This would be almost identical to the factory arrangement.
I did lose the sway bar, no way to keep it with this kit.
Old Jan 1, 2010 | 01:40 PM
ta02zx10r's Avatar
how did you go about extending the a/c lines? Vintage air?
Old Jan 1, 2010 | 03:19 PM
koji777's Avatar
local shop that makes hydraulic lines and the such made my extensions....$25.00
Old Jan 1, 2010 | 04:44 PM
STFU racing's Avatar
here's the idle video. the shitty camera doesn't justify how loud it is.....(open cutout)
http://www.youtube.com/watch?v=weUftK89LMs
Old Jan 1, 2010 | 07:10 PM
MORE PICS!!!!
Power Steering cooler, high pressure connection
AC line extension and how we routed it.
Alcohol injection solenoid mount
Our labor department. It's hard to find sober workers these days!!
Utter Destruction
Custom power steering lines
Before mock-up
More destruction
Believe it or not, Every bolt turned was in this carport as you see here.
Just some mock up pics
This is where we plan on putting that barrier so we don't pull the heat from the condensor
Buttoning it up
Old Jan 1, 2010 | 07:37 PM
00SS4780's Avatar
Awesome job.
Old Jan 1, 2010 | 11:43 PM
IT_SS's Avatar
lol @ sober workers, great build
Old Jan 2, 2010 | 04:10 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ X2! That's a funny picture.
Old Jan 2, 2010 | 04:26 PM
98Z28CobraKiller's Avatar
Restricted User
I love the v-band clamps on the crossover. I will be doing that next time that I have to take mine apart. Why the small section of coupler in the charge pipe right before the TB?
Old Jan 2, 2010 | 06:04 PM
koji777's Avatar
The reason for the coupler is because i could find a luminum bung for my AIT sensor. I had to weld a bung in for my AIT sensor... (I used a threaded sensor), the only bung I could find was steel, the rest of my plumbing is aluminum
Old Jan 2, 2010 | 07:40 PM
  #32
itsback08's Avatar
NICE!! like to see what it puts down
Old Jan 2, 2010 | 10:06 PM
  #33
black98ws6ta's Avatar
Just a tip here, but you could have took a 1/8-3/8 thick peice of aluminum and welded it to the pipe, and then tapped it for the sensor.
Old Jan 3, 2010 | 12:32 PM
  #34
That's what we ended up doing.
I believe the reason for the extra pipe was because the kit was made for a fast intake and we ended up going vic jr. We needed an extra 6" of pipe.
