JGS wastegates
Old Jan 18, 2010 | 10:16 AM
Louis's Avatar
If you ever have to service a JGS piece, its not fun. I had a customer come thru here with a pair of them, and they do not seal well. They leak, depending on how you clock them, and it was causing major boost control issues. There might be a re-design since then, but I only use Tial and Turbo smart stuff.
Old Jan 18, 2010 | 10:36 AM
RealQuick's Avatar
Interesting? Do you recall which size(s) were leaking?
Old Jan 18, 2010 | 11:30 AM
MY99TAWS6's Avatar
Local guy was running JGS gate not sure what size on his home built setup. It seemed to work pretty good for him. I have only ran Tial personally. Turbosmart does seem to make some nice stuff too. I have ran their eboost2 and their blow offs.Also Tial blow offs.
Old Jan 18, 2010 | 12:30 PM
jt76's Avatar
I decided to stay safe and purchased a Tial 44mm wg and tial bov from speed inc
Old Jan 19, 2010 | 12:04 PM
Louis's Avatar
They were the smaller ones.
Old Jan 19, 2010 | 04:50 PM
ModularTurbo's Avatar
I believe a few gates had issues a little more than a year ago. The problem was identified and fixed.
Old Jan 19, 2010 | 05:10 PM
CarsandWomen's Avatar
is there a way to identify the gates that had issues? i have a 50mm JGS that i purchased for my setup brand new, although its been quite a while now. ive yet to use it so id like to make sure before hand.
Old Jan 19, 2010 | 10:45 PM
No, I'm sure its fine. Even if it does fail they honor their warranty, if you need help just call me.
Old Jan 19, 2010 | 10:51 PM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by jt76
my MP t76 has a .96 A/R.. i will have my WG right at the merge..
On my friends old hi-flow setup with a 76gts he was running a 38mm wg..
It's all a balance of backpressure and how low you want to be able to hold boost.
